• 23.11.2026, 19:16
LotusOmega
Vertical installation of Airplex modular system with integrated pump
Friday, September 20th 2013, 10:19pm
I'm planning an external reservoir for my build and have no need to fill or bleed coolant through a top mounted reservoir (this ).
The question is: If you're going to mount these radiators vertically - Do you have to attach the top reservoir or will the standard terminal work just as well?
Pilo
Friday, September 20th 2013, 10:54pm
Do you plan on buying that 'Airplex modular system with integrated pump' or do you have it already?
If I'm not wrong, the 'top mounted reservoir' is an optional part and not included with the 'Airplex modular system with integrated pump', and if you have already plans to integrate an external reservoir into your loop, you don't need another reservoir even less, especially not an optional part for builds without any reservoir at all. The 'standard terminal' will do just find, I guess.
Do you plan to install the radiator vertically with the pump at the bottom?
This post has been edited 1 times, last edit by "Pilo" (Sep 20th 2013, 10:56pm)
LotusOmega
Saturday, September 21st 2013, 9:24am
I'm finalizing plans for my new build, evaluating different loop layouts so haven't bought any radiators yet. I guess you're right that the top reservoir is just an option if you intend to keep that feature. I got a little bewildered reading a statement from Shoggy in the launch thread saying: "For both pump modules we will offer another reservoir which can be exchanged with the other delrin terminal. This combination allows to run the whole setup vertically". It's the last sentence I'm responding to like if you do not fit top reservoir to the airplex with pump integrated, it does not allow the whole setup to be mounted vertically. Maybe I'm not reading it right (or read it too many times) :rolleyes:
So unless other tells me different I'll give the vertical setup a go without a top reservoir - if I choose to apply the airplex with pump module solution. Pump at the bottom, of course!
Thanks for replying, much appreciated :thumbup:
This post has been edited 2 times, last edit by "LotusOmega" (Sep 21st 2013, 9:42am)
Pilo
Saturday, September 21st 2013, 11:18am
You can install the Airplex Modularity System (AMS) radiators vertical, horizontal, lying flat on one side or upright, just like any other radiators from other brands, with just the standard terminals.
But, I hope you have reconsidered, that the flange-mounted pump ends for the AMS are a little bulky, because of the integrated reservoir which is ment for an installation at the top of a case with attached 25 mm fans (thickness).
This post has been edited 1 times, last edit by "Pilo" (Sep 21st 2013, 11:20am)
LotusOmega
Sunday, September 22nd 2013, 7:47pm
Yes I know they are bulky but their potential home will be in a Caselabs TX10-D with plenty of space - and I'll be using the D5 version which is less bulky - so as long as the height of reservoir is less than- or flush with a 25mm fan, it should not be any issues with bulkiness. I'm now redirecting my concerns towards restriction with the quad pass compared to the very well refined soldering flat tube two pass design - BUT that's another topic...!
Thanks again!
