• 22.11.2026, 20:59
pilotter
??? fan control
Friday, September 27th 2013, 1:11pm
I have a aquaero5 connected to the psu, and 1 fan in fan header 1. it's showing fan rpm and voltage in aquasuite. Now how do I control the fan.if I go to the controller tab, and put in the preset value of fan 1 the power slider on 60 the volt and rpm stay the same.... Am I forgetting something? ;(
I also have 2 PAultra's when I connect them and the same fans, by using the slider output power i can regulate the speed, why not wit the aquaero 5?
update; I flashed the aquaero but still no go, think the voltage control is dead?
This post has been edited 2 times, last edit by "pilotter" (Sep 27th 2013, 8:30pm)
DarkRanger
Saturday, September 28th 2013, 1:13am
There is a special setting for header 1 on the Aquaero,, you can set it on flow or fan configuration in the Sensor Tab, maybe you should check that.
Also, make sure that you dont have the same maximum and minimum power or RPM on the Fan settings section for the header 1 because the controller value will never override the value entered in the fan header settings.
pilotter
Saturday, September 28th 2013, 7:24am
thanks darkranger. But I have tried all headers and different fans.
What ever I do, I can't control the fan
Looks like the voltage control is broken, fans always stay at 12V.
However I can't find this setting for flow or fan config....... in the sensor tab.Think it's broken. might wait for aq6 or RMA?
This post has been edited 1 times, last edit by "pilotter" (Sep 28th 2013, 7:26am)
mandrix
Saturday, September 28th 2013, 2:23pm
You can't control the speed of a fan in any of the 4 Aquaero headers?
On the Fans tab, go to Advanced settings and try setting to Power Controlled. If you are not using a software controller (Controller tab) then you should be able to move the Maximum Fan Power slider back and forth and change the fan speed.
Does this work?
Don't get confused about Fan 1 header.....it can be used either as an output header or for an extra Flow Sensor. Unless you plug in a Flow Sensor don't worry about it.....
Edit: Is this a new Aquaero? If it is everything should be functioning. If it's used, it's possible someone before blew something. Try the above and tell what you get.
This post has been edited 1 times, last edit by "mandrix" (Sep 28th 2013, 2:25pm)
