• 18.11.2026, 17:56
dseg
Aquacomputer Aquaero 24-pin ATX standby, need help please
Sunday, October 20th 2013, 5:57pm
So I this 24-pin standby to connect to my Aquaero 6 whenever it releases and I am confused about how this 24-pin works. Here is a picture of how I received it. It is pretty much an extension but splits off two contacts to a 2-pin that goes to the Aquaero, makes sense. But then I have a green wire that is just extended but is about 6 feet longer than the rest of the 3" extensions lol
And of course there are no instructions with it, so what is the point of this green wire that is so long and why is it not connected to the 2pin?
Pilo
Monday, October 21st 2013, 1:28am
It seems that the Aquaero 6 has no terminal or header for this cable on its PCB. The standby power for the Aquaero 6 comes only from the USB and this cable isn't needed and even can't connect it anymore.
Monday, October 21st 2013, 11:44am
2 Pin ist Standby Power for the AE(violet +5 Volt). Green cut and to the relay Help with the aquaero power connect - 24 pin ATX standby power / ATX break
Then must the relay be a de-energised contact, a closing contact would´t work at S5.
This post has been edited 6 times, last edit by "EnigmaG" (Oct 21st 2013, 4:03pm)
