• 03.10.2026, 09:25
delevic
High flow meter usb not working after one day
Sunday, October 27th 2013, 12:49am
I have aquacomputer high flow meter usb. After a day of work, I stopped to get flow-information. I also noticed irregularities in the readings of water temperature. It is quite slow to react to changes and gave the incorrect temperature +-1.2c. I compared with three thermometers ..... I reinstalled netframework 4.5.1 , and aquasuite... What to do ?
Best Regards
Delevic
This post has been edited 1 times, last edit by "delevic" (Oct 27th 2013, 9:45am)
b0nez
Monday, October 28th 2013, 3:50pm
Simply open your flow meter. See if the prop which is inside get stuck. If so, remove an clean it.
:rolleyes:
sylvainp
RE: High flow meter usb not working after one day
Saturday, November 2nd 2013, 6:40am
Best Regards
Delevic
Go in the sensor pages and select the Flow sensor temp and look on the right you can make a temp offset.
delevic
Saturday, January 11th 2014, 1:56pm
It was hardware issue. It is fixed by aquacomputer :)
