• 03.10.2026, 07:05
fr4nc3sco
help my aquaero 5xt goes into loop
Sunday, November 3rd 2013, 12:59pm
I have a problem my Aquaero 5XT after a while is that access must be looped like holding down the button to scroll through the pages and does not stop until the detachment mains I tried already to remove the usb cable levari the various cables and fans to make it go empty but equal after a certain number of minutes it always does well or tried to remove the batteries from the controller the same there is a remedy? or do I have to RMA? was purchased by the Italian riventore Ybris and directed me here for assistance
appel
Tuesday, November 5th 2013, 3:16pm
i tried to read it 5x and i still have no clue what you are doing and what the problem is.
fr4nc3sco
Tuesday, November 5th 2013, 6:20pm
the display starts to show all the information as fast as if you pressed the down key always, I tried to loosen the screws of 3 flared but nothing if I remove the cover front display stops making the problem as if there was a short or something on the first multi-function 3-button dispay, among other things I saw in the book reviews that there are 3 red LEDs on the keys are off on my
Nihil Simile
Wednesday, November 6th 2013, 2:23am
Sounds like you may be having the Hyper sensitivity problem with the touch capacitance button. If this is the problem I am not sure but I think in the Aqua suit you can adjust the sensitivity of the button and even disable it. I had problems with mine and when I changed the PSU the problem quit. But I believe the newer version has better hardware so if yours is fairly new this may not help might need to RMA.
