• 02.10.2026, 11:50
slyfirth
new member
Monday, November 4th 2013, 5:38pm
hi all new member just a quick one got a aquaero 5 pro also got a inline temp sensor is it ok to fit on radiator out let has I do not want to put it on my cpu block (o ring does not look good on it to say its new but get one from work)
cc01
Wednesday, November 6th 2013, 10:15am
Yes, it is okay to put the inline temp sensor on your radiator outlet.
I'm sure you're not texting to this forum so it would help with understanding what question you are asking if you wrote in sentences, even if they are brief. Thanks. :)
slyfirth
Monday, November 11th 2013, 11:23pm
ok thanks for your help :D
slyfirth
Monday, November 11th 2013, 11:29pm
just looking at the manual ?
lots of bits to this unit is there a more indepth manual two help ?(
Similar threads
