• 17.11.2026, 19:07
alasdairhurst
Aquastream XT starts with very high current.
Saturday, November 16th 2013, 11:46am
I've been running the pump fine for the past new months, however since installing windows 8.1 yesterday, the pump makes strange, very loud grinding/rattling/farting noises whenever I turn the computer on, open aquasuite or turn the computer off.
I took a look at the monitoring graph in aquasuite, and this is what i found!
As you can see, the pump starts off the chart at an insanely high amount of amps before aquasuite is started to get them down, which is obviously doing something bad to the pump. As i said, this is only after installing 8.1, and it's not the USB issue that people have been mentioning either, so does anyone have a fix for this?
alasdairhurst
Saturday, November 16th 2013, 11:51am
Actually, this should be moved to the English forum sorry, I just noticed where it was.
Saturday, November 16th 2013, 1:10pm
Have you applied the USB Fix with the actual aquasuite? If not, do that.
alasdairhurst
Saturday, November 16th 2013, 10:38pm
Not sure what you mean by applying the USB fix to the aquasuite? I applied it to the aquastream XT and that's done nothing; the ampage still shows really high at the beginning of the graph.
It seems that the software/operating system itself may not be the current issue, but like i said, this started as soon as i started upgrading to windows 8.1 and never before.
It happens right when the computer is turned on and the pump gets power, when the aquasuite is started, and when the computer looses power on shutdown. the pump shakes quite a bit and the sound is also similar to violent water frothing and pump vibrations.
could it be a firmware issue? I mean it could have corrupted somehow for some reason or other.
edit-
I removed the USB connection to the motherboard and started up the computer, and the pump just kept increasing in speed to the point when it sounded like a washing machine and was forcing water around the system crazily. obviously i turned it off then reconnected the USB to keep it under control, but this time both the current and rotations started off high, went lower then 3000rpm, then settling at 3000rpm/50hz with the current at 0.5A
This post has been edited 1 times, last edit by "alasdairhurst" (Nov 16th 2013, 10:48pm)
alasdairhurst
Tuesday, November 19th 2013, 10:45pm
Any input guys?
Wednesday, November 20th 2013, 7:30am
Open aquasuite 2013-4 and goto: System page.
In the bottom of the page is a Tab to apply a USB Fix.
alasdairhurst
Thursday, November 21st 2013, 12:13pm
nope, updated aquasuite, applied the fix, restarted. nothing. It isn't cutting out, so i wouldn't have thought that the sleep on USB device thing wouldnt be anything to do with it.
alasdairhurst
Saturday, November 23rd 2013, 11:40am
Sebastian?
alasdairhurst
Tuesday, December 24th 2013, 6:20pm
Bump again. I would really like some support on this.
For various reasons I reinstalled windows 8 on the computer, and the pump was silent for the most of it, but after upgrading to 8.1, as before the pump started going mental and literally making very harsh "farting" noises when starting, shutting down and installing.
wa3pnt
Wednesday, December 25th 2013, 4:10am
I'm running Aquasuite 2013-5.2, and there is no USB Fix on the Aquasuite Settings page. Is this something that was specifically for 2013-4?
RodeoGeorge
Thursday, December 26th 2013, 9:56am
It's only for Windows 8.1.
Please disconnect the USB and try if the problem is still the same.
alasdairhurst
Saturday, December 28th 2013, 3:16pm
I've ended up reverting back to windows 8. 8.1 has only been trouble for me. It's not like i have old hardware too... (4770k, GTX780 etc...)
Reverting to windows 8 has stopped any noise from the pump. The worst noises weren't even when the operating system was running which was VERY strange (booting up and shutting down the computer) and the worst was when installing windows 8.1 when it was configuring. Windows 8 hasn't had any of these problems when installing and running and i haven't heard a thing from it.
Also it looks like the pump and the fan controller have kept their profiles i set previously, so i haven't even had to install aquasuite so that speeds things up a bit on boot.
