• 30.11.2026, 23:02
fr4nc3sco
help switch Frontplate for aquaero 6 XT
Friday, November 29th 2013, 6:48pm
hello guys know how to change the bezel with silver to black? aplicato goes over the silver or the silver should be lifted because apparently soldered to the bottom and I would not do any damage what is the correct procedure?
Pilo
Saturday, November 30th 2013, 3:32am
It's just a simple bezel without any electronic components soldered to it like to the optional replacement front plate. I think you only need to unscrew the four screws in the front corners and the bezel should be seperately removeable.
Just the Bezel:
Replacment Frontplate:
Front:
Back:
This post has been edited 1 times, last edit by "Pilo" (Nov 30th 2013, 3:33am)
fr4nc3sco
Saturday, November 30th 2013, 6:01am
not raised the screws to the plate remains solid below and I would not give damage to leverage
delevic
Saturday, January 11th 2014, 2:36pm
I have same problem :) seems to be that default mask is glued with pcb.
wa3pnt
Sunday, January 12th 2014, 3:40am
Those are two different Front plates, and they are not compatible.
One has a hole for the IR sensor, and the other has a slot.
If you look on this web site, you'll see that they are not compatible.
http://www.frozencpu.com/cat/l3/g/c17/s4…lers-Page1.html
RodeoGeorge
delevic
Sunday, January 12th 2014, 8:27pm
This is not a compatibility problem :) The question is how to remove default frontplate
delevic
Monday, January 13th 2014, 4:25pm
I received a response from aquacompuer about frontplate :
"Yes. The front is glued.You should use a flat screwdriver or knife and start at one corner and carefully split away the front step by step."
But my advice is to use vCard, or some plastic knife for paper :)
delevic
Saturday, January 18th 2014, 11:09am
Done :)
