• 06.10.2026, 18:09
Piopi_2
Pump adapter for D5 - water leakage
Sunday, December 15th 2013, 7:55pm
Hi!
I bought pump adapter for D5 pumps for aqualis base with fill level sensor (http://shop.aquacomputer.de/product_info…roducts_id=2926 ).
In the process of filling system distillate, it was found that this adapter has a water leak from the location of the board aquabus:
http://youtu.be/eWwXCZEovI8
What to do?
Piopi_2
Monday, December 16th 2013, 3:46pm
Silence on email, here you too silent. I bought your company's products to 350 euros (pump adapter for D5, aqualis base for pump adapters 450 ml with fountain effect and nano coating, aquaero 5 PRO, Aqua Computer D5 - 2 pcs.) I understand it as disrespectful to me as a your customer.
Your products are not passed the final test, because even a blind man would have seen any water leakage. What German quality do you say? Product assembly occurred with defects and gaps. Your fault and you are silent.
I'm on all Russian forums discourage maximum number of people from buying your products. Thank you for your help.
Jakusonfire
Monday, December 16th 2013, 4:18pm
There must be an o-ring leaking around the sensor. If you take out the mps board it should be pretty easy to fix. You will need to take the pump top out of the loop though of course.
Piopi_2
Monday, December 16th 2013, 4:55pm
Easy to fix?
One o-ring does not have sufficient downforce.
I performed an experiment.
1. set board mps as it was originally installed, syringe hole on the top cover under the pressure of the water cast out.
Water began leak where there is a o-ring.
2. If the o-ring finger pressed to the body of the adapter, the water began leak from the other end of the sensor, which has not set the o-ring manufacturer.
I think that holes for the sensor made ​​too wide or ring too thin.
In general, the manufacturer must test the final product. And here we have a real defect. Manufacturer said not a word.
Piopi_2 has attached the following image:
Piopi_2
Tuesday, December 17th 2013, 5:10pm
my mps board and mps board my friend. differences
support save silent
Piopi_2 has attached the following images:
TheUnderWonder
Thursday, January 9th 2014, 9:51pm
Has anyone found a solution for this or heard back from Aquacomputer yet? I have two pump adapters and they are both leaking in the exact same way. I really need to get this fixed so that I can get my loop up and running.
Piopi_2
Tuesday, August 5th 2014, 7:30am
After all support me answer. And send a new adapter. Everything is fine!
