• 08.10.2026, 04:17
paulstung
how to use than fan control of the LT
Monday, January 20th 2014, 4:27am
I've just bought the Aquaero 5 Lt mainly for the fan control, but how does it work ? I have installed the latest Aquasuite software, but there are no fan options. I have the unit plugged into a molex for power, the USB connector plugged into the motherboard, and the 4 pin signal cable plugged into the motherboards CPU 1 fan header. Please help my pc sounds like a turbine...
Monday, January 20th 2014, 4:42am
4pin? Not a 3 Pin? To Tacho(RPM)?
This post has been edited 1 times, last edit by "EnigmaG" (Jan 20th 2014, 6:00am)
Monday, January 20th 2014, 7:16am
Please disconnect your aquaero befor you damage it!
Take a look to the deatailed Manual at:
http://aquacomputer.de/handbuecher.html
