• 09.10.2026, 20:14
Railgun
Over current with nothing connected
Sunday, February 9th 2014, 8:47pm
It seems I've developed an issue with my 6 XT in that two outputs that I have configured for PWM output, and has not seen any actual load (devices are connected to separate power) have all of a sudden given me over current alarms on both outputs 1 and 2.
Other than some disconnecting and reconnecting from removing and re-installing, nothing's changed.
I've reset the device, and even with nothing connected other than owner, it still gives that alarm.
I can't imagine that both outputs would have simultaneously failed. Just PWM and RPM signal are connected to those particular headers.
I'm open to suggestions.
Thanks in advance.
Railgun
Tuesday, February 11th 2014, 11:34pm
Still open to ideas. :)
Wednesday, February 12th 2014, 6:54am
Reset your device to factory defaults.
Then try it again. Have you problems when your fans in voltage controlled mode?
Railgun
Wednesday, February 12th 2014, 8:46am
I've already reset the device. As soon as it turns on it throws up the alarm. As by default it is voltage control, yes, it has the same issue.
Wednesday, February 12th 2014, 9:14am
Disconnect the load from the fan outputs. Is output is running without load?
Railgun
Wednesday, February 12th 2014, 9:45am
There is nothing connected to the unit other than main power. The alarm is given about 3 second after initial power up. No fans, no sensors, nothing.
Wednesday, February 12th 2014, 11:41am
Your device has an defect. Send it to you dealer oder write a mail to: info@aqua-computer.de
