• 11.10.2026, 01:04
Neoload
Double Protect Coolant Biocede Require?
Sunday, February 16th 2014, 1:17am
I have a question regarding the Double Protect Coolant and the Glow motion Coolant
From what i understand these had inhibitors for disimilar metals but do they have biocede to protect against algae?
Would i need to use a silver coil, biocede additive?
Thankyou :)
Shizbazki
Sunday, February 16th 2014, 4:30am
Most coolants from various companies have biocides, you can add a silver coil as it don't cost a huge amount extra.
Personally i use deionized water and normal car anti freeze which has done me well over several years causing no build up of algae or corrosion in dissimilar metaks
Pilo
Sunday, February 16th 2014, 6:41am
I filled up my loop, which contains a 5 1/4" Koolance Drive Bay Reservoir, a CPU water block, two full cover GPU water blocks, >4 meter of 13/10 tubing, a 360 Aquaduct and a 9x140 Mo-Ra 3 Radiator with only one bottle of clear Double Protect Ultra and distilled water only. The loop is running over 2 years now without replacing the coolant. I just filled up the evaporated water with new distilled water again and again and nothing else and have no problems with algae till today. The coolant is as clear as 2 years ago. But I must say, that I never flushed the loop and components with tap water, because piped water contains a small amount of algae which remain in the water cooling loop after rinsing. The algae multiplies after time in the warm cooling water without water additives. You must consider though, the abstain of using tap water for flushing the loop could be the main reason why my coolant is almost as new as two years ago. Nevertheless, it also could be the effect of the Double Protect Ultra, even after diluting it this much.
Neoload
Sunday, February 16th 2014, 1:34pm
https://www.dropbox.com/s/cy3u10r3qmuizz…%2022.24.42.jpg
The issue I am having is the water in the loop has started to go bad I think. Take a look at the picture above.
In my loop I have used:
Kyros HF 1155 socket
Primo chill LRT Tubing
EK MOSFET block (Perspex)
EK XTX Radiators
Monsoon white Fittings
Aqua stream XT Ultra Pump
X3 250 Rez
I have put pure double protect clear in the loop n dropped a silver coil in the Rez.
Help Please :S
This post has been edited 1 times, last edit by "Neoload" (Feb 16th 2014, 1:35pm)
bcikota
Sunday, February 16th 2014, 3:52pm
Hi Neoload,
How long has your loop been running for? At first glance it does not look like algae to me, but more like the flux residue from the radiators. Did you flush them properly before assembling the loop?
I've been running my latest loop with just pure distilled water and a silver coil for 6 months now and no problems so far.
Kind regards,
Boris.
Neoload
Saturday, February 22nd 2014, 7:06pm
My loop has been running for around 5 months. I flushed the radiators out with distilled water.
