• 10.10.2026, 22:47
ltorsini
Bad math?
Thursday, February 20th 2014, 5:55pm
Hello All -
I am new to the forum and Aquasuite but am enjoying both. I have a problem setting up a virtual sensor, it appears that the software miscalculates the data. I'm trying to run my cooler fan speed off of a temp delta (see attached file 'bad math') and have a CPU temp of 93 and a cooler outlet temp of 80. 93-80=12 but the Aquasuite software gives a value of 42. I've tried changing to C, reloading the software and switching between modes but nothing seems to do the trick. The same happens with the other delta algorithm I use to control my case fans. Both system and Aquasuite settings have Farenheit selected.
Any insights?
ltorsini has attached the following image:
Friday, February 21st 2014, 6:52am
The aquaero claculate all internal values in K and °C.
The differences are internal stored in K. The conversion from a difference is not possible to °F in this case.
Similar threads
