• 17.11.2026, 04:42
damianz
Question about pwm settings in aquaero 5
Tuesday, February 25th 2014, 12:45pm
Hello,
I'm planning to buy Aquaero 5 in LT version, but i need to get answer to this question first.
What i want to achive is completly silent pc in idle.
I've got two 140 mm prolimatech ultra sleek vortex fans on my cpu ( pwm ).
In Aquaero 5 is only one pwm fan slot, so i understant that i will need to use some spliter to cennect them.
But here is my main question - does aquasuite allows to turn off pwm's fans or only reduce their speed to minimum rpm ?
If i connect them to "standard" 3 pin slot in Aq 5, would i be able to stop them from spinning by reducing voltage level in aquasutie ?
thanks in advance
Pilo
Wednesday, February 26th 2014, 6:11am
I have read a statement of a staff member from AC, that it will be possible to shut down a PWMs fan completely with a new firmware for the Aquaeros with the release of a new Aquasuite 2014 version in the future. It was some month ago, so this feature could be already implemented. But I'm not sure if it's already done. But it's planned, because some other users asked the same before you. ;)
Similar threads
