• 22.11.2026, 21:34
MRPerson
PUMP broken?
Monday, March 31st 2014, 9:59pm
Hiya,
This just happened today totally unexpected, my computer shutdown because of overheating of cpu. After checking what's going on noticed that the D5 pump connected to Aquaero 5LT via USB and aquabus, had stopped running. The pump still shows up correctly in aquasuite, I can change all the settings, but the rpm count stays in 0. I updated the aquasuite to 2014.1.3, and both the aquaero and pump firmwares. And ofc checked that there is power coming for the pump. Before that I didn't do any changes to the system, it has been running just fine for 6months.
Pump D5
Firmware: 1008
Boot loader : 1001
Hardware:1100
Serial: 4132
Aquaero 5LT
Firmware: 1036
Boot loader: 101
Hardware: 5600
So is the pump just burned, or something wrong with the program?
madcratebuilder
Wednesday, April 2nd 2014, 2:29pm
You can test the pump with just the 4 pin molex connected, it should run, if not then, it's dead Jim.
MRPerson
Wednesday, April 2nd 2014, 4:17pm
Well then its kaput. :/ Thanks for the answer.
