• 07.10.2026, 07:19
kshafe777
no instructions for Aquaero 6 XT included???
Wednesday, April 2nd 2014, 10:27pm
I just purchased the Aquaero 6 XT... It did not come with any instructions , which I found strange... and the quick start guide is worthless.
please help... :)
~Kevin~
Phanteks Enthoo Asus Crosshair V Formula Z AMD Vishera 8350 ASUS GTX 780Ti DCUIIOC 32 GB G.Skill 2133 9L RAM Corsair ax860i
EK Supremacy CPU Block EK FC Asus GTX 780Ti DCII Full block ( on the way :) ) EK D5 pump EK x3 150 res
420 Alphacool rad - 30mm 280 Alphacool rad - 60mm 280 Alphacool rad - 45mm Noctua NF-A14 PWM's Aquaero 6XT
b0nez
Wednesday, April 2nd 2014, 11:43pm
You have to download the manual.
:rolleyes:
kshafe777
Thursday, April 3rd 2014, 12:21am
awesome! thank you so much!
~Kevin~
kshafe777
Thursday, April 3rd 2014, 5:24am
wow... um... these "instructions" are HORRIBLE! They don't "instruct" you on anything. No directions of how/where to hook up the various sensors and cabling. Nothing.
im returning this Aquaero 6 XT and getting a Phobya instead. Purely because of the lack of real "instructions."
~Lost Customer :!:
~Kevin~
Thursday, April 3rd 2014, 6:52am
The manual describe ALL connectors and the connections. You have to read all pages.
kshafe777
Thursday, April 3rd 2014, 7:18am
Correct. It "describes" them.... But it doesn't actually tell you how or where to install them. The manual assumes prior knowledge of fan controllers and use... But does nothing for the person who has never installed a controller before. They are garbage instructions.
~Kevin~
madcratebuilder
Monday, April 7th 2014, 3:54pm
The manual isn't a "How To" setup guide. The user must define their own setup as each system is different.
If you Google it, you can find set up guides for the AQ5&6. The AQ6 isn't a device for the novice user, it's sophisticated programing puts it a league of it's own among controllers. Install the AQ6, load the Aqua Suite program and play with it, it's pretty intuitive. If you fubar it just reset to factory defaults and start over. It's no more difficult than learning a new OS.
When you buy a car it's assumed you know how to drive.
Similar threads
