• 08.10.2026, 08:07
deepdelver
Nees help my computer is switching off in few seconds after start
Tuesday, April 8th 2014, 1:40pm
Hellow all, i just finished my watercooling system but when im starting it its turns off shortly after, and doint it even if pump is not connected. Even if im taking motherboard out of system and discconecting evrything it wont work. But day after that motherborad begun to work again, but when i connected all back it came back and it turn off again. Im usin pump
aquastream XT USB 12V Pumpe - Ultra Version
can someone help me with some tips whats kinde of problem is it ? is it motherboard destroed or im doing wrong with a pump ? PSU is sapphire pure 1250w
wa3pnt
Tuesday, April 8th 2014, 5:08pm
We need a lot more information before we can help.
1. What is connected to the Motherboard CPU Fan Header to supply that RPM Signal?
2. Are you using any software (Aquasuite) to control the Pump?
3. If #2 is YES, do you have any Alarms configured?
You can try connecting a fan to the CPU Fan Header to provide the RPM Signal, and see if the system shuts down. That will indicate that whatever you normally have connected is causing the problem.
RodeoGeorge
Gabrielzm
RE: Nees help my computer is switching off in few seconds after start
Tuesday, April 8th 2014, 10:15pm
What motherboard do you have? As wa3pnt pointed out what is connected to the cpu fan header? Can you get in to BIOS or just turn off after a few seconds and stays off?
