• 28.09.2026, 17:32
cincilleo
mps sensor 400 calibration - wrong values
Monday, April 21st 2014, 2:22pm
Hi, lot of time ago i posted a problem with this mps 400 that give me too high values.
Now i modified my loop and is:
LAING 500 18W->2 BLOCK SLI GTX680 CONNECTED BY GPUX FROM HEATKILLER BRIDGE->RAD360->EK SUPREME HF->RAD 280->RESERVOIR OVER PUMP XSPC.
Now... 395 lt/h is like a joke it's IMPOSSIBLE
Why i have so high value? I spend money in things that return bad values?
Very sad... hope that someone help me to resolve this issue
cincilleo
Tuesday, April 22nd 2014, 12:28am
nobody has a similar problem??? I don't believe it!
wa3pnt
Tuesday, April 22nd 2014, 1:16am
Have you used the correct calibration settings?
I have three of the MPS-400s, and they all are very accurate (when compared to the readings I tested with a Koolance Flow Sensor).
RodeoGeorge
cincilleo
Tuesday, April 22nd 2014, 1:54pm
All settings is correct.
Tonight i will calibrate manually with a tank and a watch. Old method is always the best.
how much flow is the normal with a loop like the mine?
