• 05.10.2026, 07:59
icewolf69
Help with new Aquaero setup
Tuesday, April 29th 2014, 9:20pm
Sorry about my post in the German forums, I finally figured out how to post in the English forums.
Hi all,
I'm building my new computer and i'm going to be putting in an aquaero 6 XT into it. But i'm not finding a lot of information on what products i need to do what I want.
I'll have 2 pumps, but i have so many fans i won't have the power to control the fans AND the pumps. So i'm just going to use the Aquaero for 54 fans. I need 2 water temp sensors and a flow sensor.
So what i have down so far would be:
Aquaero 6 XT (53146)
Passive heatsink (53164)
1 high flow USB sensor (53129)
temperature sensor internal/external G1/4 for after a radiator (53067)
Temperature sensor inline, for the middle of the tubing (53066)
Will all of these work together? do i have the correct cables? Am i missing anything here?
Thanks!
mandrix
Wednesday, April 30th 2014, 1:14am
Looks OK to me. You can use up to 8 sensors, you know, so you are good there.
If the fans aren't the pwm type then just do the math and make sure you aren't overloading the Aquaero.
