• 29.11.2026, 14:38
Mega Man
i need help with aquaero 6xt + multiswitch setup
Saturday, May 3rd 2014, 6:01pm
ok. so i can use the multiswitch via usb and aquasuite 4.xx without issue.
updated to most recent firmware.
reinstalled aquasuite 2014.
shut off, installed jumper 3 and removed usb.
installed aquabus cable on multiswitch ( both aquabus channels ) and on LOW speed aquabus on aq6xt.
i can not get aquaero 2014 to recognize it, am i doing something wrong ?
micpt
Monday, May 5th 2014, 8:42pm
when connected via aquabus - you will find the multiswitch options under Aquero Output. There you will find the 8 LED Out´s and also the 8 Power Out´s.
Via Aquabus MS will not be shown as own unit.
In my Screenshot Multiswitch options start with MS1
This post has been edited 1 times, last edit by "micpt" (May 5th 2014, 8:45pm)
Mega Man
Tuesday, May 6th 2014, 4:03am
that is the problem.
it is not showing up, it does not even show anything connected via the aquabus ( under settings- devices connected via aquabus )
Tuesday, May 6th 2014, 9:35am
From the multiswitch manual:
Quoted
Jumper position 5: USB/aquabus
This jumper configures which interface of the multiswitch is active.
Jumper open: USB enabled, aquabus disabled
Jumper closed: aquabus enabled, USB disabled
Mega Man
Tuesday, May 6th 2014, 2:55pm
i knew i forgot something stupid, thanks !~ will test now
