• 19.11.2026, 14:06
dopax007
I need advice about of filter from aquacomputer
Friday, June 6th 2014, 10:34pm
I would greatly appreciate your opinion on Aquacomputer filter ; I've one but want to know if it is really useful in the liquid cooling loop before adding ,besides ignoring that part of the loop would be advisable to place .
Not know its advantages and disadvantages and so I would like to know your opinion about it.
Thanks in advance
Namron
Saturday, June 7th 2014, 12:08am
Personally I've never ever seen a need for or used a filter in a PC cooling loop!!... It's Just something to cause a restriction in my opinion that has never been needed :D ..
That's just my opinion you understand, I have been using the Aquaero's since they came out & water cooled all my PC's including my PC'c I use for all my reviewing e.t.c..
N.
madcratebuilder
Saturday, June 7th 2014, 1:59pm
I've been using the AQ filter for about six months, it's not as restrictive as I thought it would be, I did not see any change in flow rate on a dual d5 loop.
After seeing so many threads about debris in loops I felt the extra possible restriction was worth it and the filter could give me a immediate indication of loop contamination. After six months the filter is spotless so I may remove it on the next loop maintenance, or I may not. I added a led plexli plug to the back for a 5mm led and use the AQ6 for a temp base light show in the AQ filter window.
dopax007
Saturday, June 7th 2014, 9:46pm
Thanks for your replies .......... the truth is either more or less restrictive, the main question is whether it is really necessary over time.
Before mounting the loop thoroughly clean my radiators and I was very careful to preserve any impurity of the assembly; even rinse with distilled water each cooling block.
What I don't know is, if over time ( I use distilled water with additive Innovatek PRO in a 3:1 ratio ) , the coolant can create impurities that warrant the use of this filter.
I hope more reviews about ............ the debate can be interesting.
Greetings
madcratebuilder
Sunday, June 8th 2014, 2:23pm
I think most "junk" you see in loops is from users not using a biocide or cheap tubing leeching plasticizers. Some dye additives can cause problems. Flush your blocks and rads, use distilled water and biocide you should not need a filter.
This post has been edited 1 times, last edit by "madcratebuilder" (Jun 8th 2014, 2:25pm)
madcratebuilder
Sunday, June 8th 2014, 2:24pm
doubled.
dopax007
Monday, June 9th 2014, 11:21am
thanks madcratebuilder ..............so far , what I have researched on the subject in various threads , I do fully agree with you..
I would like to meet the objective opinion of Shoggy ( and anyone who wants to give it ) ; although Shoggy may seem like a "partial" person in that opinión , I trust your judgment and professionalism
Marucins
Monday, January 20th 2020, 5:51pm
/sorry for unearthing the topic, but it was the latest on the subject.
I have to buy a filter.
Of course, the choice fell on https://shop.aquacomputer.de/product_inf…roducts_id=2421
- What is the default filter mounting plate?
- In what position should the filter be installed (horizontally / vertically) so as not to drain the water when cleaning?
I wonder where I can mount the filter - what patents do you know?
On the fan, next to the fan, some special mounting frame, etc.
//edit
I was thinking about 5.25 bay. I have two free places.
Will Aquacomputer Flter fit there with the default mounting frame size?
This post has been edited 1 times, last edit by "Marucins" (Jan 21st 2020, 7:32am)
