• 13.10.2026, 09:45
dopax007
doubt about the connection of 2 pumps MCP35X to my aquaero 5XT
Monday, June 9th 2014, 11:57am
Greetings to all:
I need your advice about which option to choose to connect my 2 pumps MCP35X to my aquaero 5XT , on the subject's monitor RPM pumps ...............I've these pumps in the top dual EK V.2.
¿ What would be the best option ?
1-connect the two pumps at Aquaero fan connector No. 4 in PWM mode with a 4-pin Y splitter , monitoring the RPM of a single pump
2-connect the two pumps in the same way as in the previous option but with a splitter that has an additional 3-pin connector , connecting said connector to another connector for fan in the Aquaero , and can also monitor the RPM of both pumps , but sacrificing thus for possible use with fans.
There are more options? (I have 4x Poweradjust 2)
Thanks in advance
mandrix
Tuesday, June 10th 2014, 11:40pm
What I do is connect to the #4 fan header but powered from the psu....I only monitor rpm's from one pump but pwm signal from both pumps. Never really saw a need to monitor rpm from both pumps (MCP35x2).
dopax007
Wednesday, June 11th 2014, 10:26pm
That is also the way I had it connected ............... however , I read in some thread that some connect in this way ( monitoring both RPM's ) and wanted to know if there is any real benefit that I'dont know in this way.
mandrix
Wednesday, June 11th 2014, 10:49pm
None that I can see, just takes up another header only to monitor the other pump. But this is the internet, people will tell you every possible way to do something. 8)
dopax007
Thursday, June 12th 2014, 12:09pm
Thanks , mandrix...........i'lltake in account
