• 20.11.2026, 15:26
Psychor
Aquasuite 2014-1.3 Crashing (Windows 8.1 x64)
Wednesday, June 25th 2014, 12:22am
I recently upgraded from AS 2013-x.x to AS 2014-1.3. I'm running the latest version of Win 8.1 Enterprise (x64). Since upgrading my system regularly (e.g., daily) locks up due to AS crashing. I've had to resort to disabling AS from automatically starting on Windows boot now. :thumbdown: While this "fixed" the issue it is far from ideal. I've never had these issues with AS 2013-x.x.
I pulled the following from the Windows Event Log:
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
Faulting application name: aquasuite.exe, version: 1.0.0.16, time stamp: 0x52dfabaf
Faulting module name: KERNELBASE.dll, version: 6.3.9600.17055, time stamp: 0x532954fb
Exception code: 0xe0434352
Fault offset: 0x0000000000005bf8
Faulting process id: 0xd24
Faulting application start time: 0x01cf874ab3d45a42
Faulting application path: C:\Apps\aquasuite\aquasuite.exe
Faulting module path: C:\WINDOWS\system32\KERNELBASE.dll
Report Id: 49856539-f3ed-11e3-8000-c86000002806
Faulting package full name:
Faulting package-relative application ID:
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Application: aquasuite.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Data.SQLite.SQLiteException
Stack:
   at System.Data.SQLite.SQLite3.Reset(System.Data.SQLite.SQLiteStatement)
   at System.Data.SQLite.SQLite3.Step(System.Data.SQLite.SQLiteStatement)
   at System.Data.SQLite.SQLiteDataReader.NextResult()
   at System.Data.SQLite.SQLiteCommand.ExecuteReader(System.Data.CommandBehavior)
   at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
   at AquaComputer.Logdata.LoggingProcess+LoggingCache.CommitToDatabase(Boolean)
   at AquaComputer.Logdata.LoggingProcess.workerThreadMethod(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Threading.ThreadHelper.ThreadStart(System.Object)
Anyone else notice this?
Thanks.
This post has been edited 1 times, last edit by "Psychor" (Jun 25th 2014, 12:24am)
Wednesday, June 25th 2014, 6:55am
Do a clean install from the aquasuite. I think this is depend on wrong old settings in your system.
To help us you can send us your data folder:
zip the folder with all files:
Source code
1
C:\ProgramData\aquasuite-data
and send it to: info@aqua-computer.de
Similar threads
