• 12.10.2026, 13:24
Ausbullant
aquacomputer kryographics waterblock compatibility
Saturday, June 28th 2014, 3:47am
Hi all
I am building a new water cooled PC and have purchased Aquacomputer Kryographics waterblock for R9 290X GPU. Can anyone tell me if these water blocks are compatible with all R9 290X cards or only stock reference cards. ie Will they fit the http://www.asus.com/au/Graphics_Cards/ROG_MATRIXR9290XP4GD5/ or the MSI Lightning R9 290X?
Thanks
Greg
Jakusonfire
Saturday, June 28th 2014, 9:19am
They will only fit reference cards, and definately not Matrix, Lightning etc cards
Those cards use custom designed PCB's and have water blocks specially designed for them that only fit them.
This post has been edited 1 times, last edit by "Jakusonfire" (Jun 28th 2014, 9:20am)
Ausbullant
Monday, June 30th 2014, 6:33am
Thanks again for the reply Jakusonfire.
I am now planning on using:
http://www.pcper.com/reviews/Graphics-Ca…ics-Card-Review
It says it is a stock reference PCB design.
Is there anyone else out there that has used the aquacomputer kryogriphics Hawaii waterblock and if so what card did you use?
thank you :schland:
This post has been edited 4 times, last edit by "Ausbullant" (Jul 1st 2014, 12:45pm)
Jakusonfire
Monday, June 30th 2014, 2:43pm
No, The Asus DirectCUll cards are custom PCB designs and Aquacomp don't make blocks for them.
Edit: In general if a card will fit one reference water block it will fit another so, other brands have lists of cards that fit.
http://gpu.watercool.de/WATERCOOL_HEATKI…mpatibility.pdf
http://www.coolingconfigurator.com/waterblock/3831109868539
This isn't a guarantee though, and cards are sometimes revised by the manufacturers and are no longer reference.
This post has been edited 1 times, last edit by "Jakusonfire" (Jul 1st 2014, 2:07pm)
Ausbullant
Tuesday, July 1st 2014, 12:47pm
Thanks again Jakusonfire
I have edited my orig q. see above.
gdesmo
Tri-X compatibility
Friday, August 1st 2014, 3:42am
This isn't a guarantee though, and cards are sometimes revised by the manufacturers and are no longer reference. Reply > The Sapphire Tri-X will definately fit the Kryographics card, I checked my AMD Factory 290 and the PCB is identical. Here's a pic of my 290 block that I gold-plated myself.
gdesmo has attached the following image:
