• 15.11.2026, 16:24
fede3d
i need help with aquaero 6xt
Wednesday, July 9th 2014, 9:23pm
Hi all guys.
I need to connect 2 flow sensors and 2 pumps (LAING D5) to my aquaero 6 xt.
How should I do that?
Is a single aquaero 6 xt controller enough or should I need some other module?
Last question:
Is there a way to automatically adjust the fan speed and the pump power
depending on the temperatures that the sensors read?
Thanks in advance, bye!
This post has been edited 1 times, last edit by "fede3d" (Jul 9th 2014, 9:26pm)
Thursday, July 10th 2014, 7:13am
The 2 flow sensors are not the problem. You can connect the sensors to "Flow and Fan1" connectors.
But your pump is not compatible with the aquaero.
Read this:
Help with Aquaero 6 XT PWM controller.
fede3d
pumps
Thursday, July 10th 2014, 12:15pm
OK. please, could you tell me which pumps are compatible?
ty
Thursday, July 10th 2014, 1:18pm
The normal D5 without PWM.
Similar threads
