• 10.10.2026, 23:33
eacmen
Aquacomputer AIrplex Newbie Question
Tuesday, July 15th 2014, 6:25pm
I am new to aquacomputer, but not new to water cooling. I bought the airplex 360 with integrated pump and reservoir. Hooked everything up, filled the reservoir, turned the pump on but nothing seems to happen. I hear the pump turning, once and while I will see a few bubbles - but there is no water getting pumped into the loop. The reservoir has 2 IN and 2 OUT G 1/4 fittings, I am using the two on the bottom. Is there something special I need to do to fill the loop correctly? I am feeling pretty dumb right now. Any insight would be appreciated.
Friday, July 18th 2014, 12:12pm
The pumps are not able to move air so if the pump is not already flooded with water nothing will happen except a rattling noise. You should just tilt the radiator a bit to different sides or maybe also shake it to get the air out of the pump.
