• 22.11.2026, 23:53
Bytales
RGB Diodes in Aquaaero 6 XT
Saturday, October 11th 2014, 6:42pm
After reading in the manual it says like this:
Connector „RGB LED“
Connector for up to three LEDs or one two-color or RGB illumination module
(not included in delivery).
Using a RGB Module like the one here , inside a plug like this one , that goes inside a reservoir on the bottom (could that be used inside this reservoir here (thats made from 3 different pieces) ?, if not, which reservoirs compatible with this combination ?) one could control the led based on water temperature, or delta, (if two sensor are within the same loop at different points) to make it different colors.
The question is, if one can connect more that 1 RGB illumination modules, meaning 2, to the aquaaero 6 XT, or do i need to get something extra ?
Monday, October 13th 2014, 9:43am
You can only use one RGB LED wiht the aquaero. Two or more LEDs would overload the output and could damage the electronic.
The mentioned transparent plug can be used to install the LED to the reservoir.
Bytales
Monday, October 13th 2014, 10:34am
Thanks for all the answers Shoggy, here, and in my other Threads.
Now, how could i use 2 of these RGB Leds, if the aquaero 6 can drive only one ?
Through eny other equipement you may offer, ?
Or am i stuck with only one ?
Monday, October 13th 2014, 11:48am
We do not offer anything that will work with two ... yet ;)
Bytales
Monday, October 13th 2014, 2:01pm
Now theres something thats going to need to get upgraded ! At least now i know !
wa3pnt
Monday, October 13th 2014, 8:25pm
This is what I use with the Aquaero 6XT to drive about 8 feet of RGB Strip lighting.
Works GREAT!
Jeak RGB Amp
RodeoGeorge
mcrustk2
Saturday, August 14th 2021, 7:49pm
Hi @Shoggy, has this changed? I have an Aquaro 6LT and two illumination modules I would like to use to illuminate two of your filters, is there anything I can use to make this work?
Thanks,
This post has been edited 1 times, last edit by "mcrustk2" (Aug 18th 2021, 6:37pm)
