• 11.10.2026, 17:18
Bytales
Dimensions of reservoir/pump mounting mechanism
Sunday, October 12th 2014, 11:07am
So im currently trying to decide between radiator/pump/reservoir combination and reservoir/pump combination with bare radiator.
I would like to know what distance are between the mounting points, look at this picture here !
Does it fit on a 140mm/120mm/92mm/80mm fan mount ? I will not be drilling in my case, i will be using fan adapter, i got tons of mounting possibilities, just like to know before which one will fit.
Does anyone know ?
Monday, October 13th 2014, 9:54am
The inner dimensions of the quadrat with a screw head as center in mind are 80 x 72 mm and the outter dimensions are 91 x 83mm.
It does not fit any common fan size.
Bytales
Monday, October 13th 2014, 6:34pm
So you would basically have to drill the holes that will fit the mounitng brackets, if its not any standard dimension, right ?
You could always offer a plate that would fit a 120 or 140 mm mount that has the holes that would fit its mounting mechanism. THis plate would then go in the mounting holes of 120, 140mm fans, and then thorugh this mounting plate you could attach the pump/reservoir combo !
One could of course do said plate thorugh a custom firma, like Emachinesshop !
Something to think of in the future, most definitely.
Cause i was planing 2 loops, with 2 pumps per loop, one attached to the radiator, one attached to the reservoir, for each loop.
They would run in serial.
And i was thinking on attaching a rgb led to the reservoir and control it based on loop temperature, for each loop, but alas, as you said, only one rgb connector is allowed for the aquaero 6 xt, and there is no other way a second could be connected.
This post has been edited 3 times, last edit by "Bytales" (Oct 13th 2014, 6:40pm)
Similar threads
