• 11.11.2026, 06:45
dsadfsgffdg
schedule a profile
Thursday, November 6th 2014, 11:49pm
is there anyway to schedule profiles to run say via a batch file. The profiles which are all .pro files. I have never managed to get profiles to work via the timer or via the font bay lcd. It would be great to be able to run a profile via command line. If i try and run a profile all that happens is that the aquasuite software opens but it doesnt load the profile. I have to import it for it to work.
Friday, November 7th 2014, 8:31am
Profiles that are stored external can not be loaded this way. You have to use the four internal profiles of the aquaero. You can manually switch between them only directly on the device but an automatic switching can be also done with the timer settings in the aquasuite for example.
dsadfsgffdg
Friday, November 7th 2014, 10:53pm
Thanks. I have tried doing it that way but just doesnt seem to switch. what is the timer section of aquasuite for exactly then?
Saturday, November 8th 2014, 11:15am
Make sure that you make different settings in the profiles. The aquasuite will not be able to tell which profile you currently use. You have to select this manually on the device before you do your settings and then changes in the aquasuite will be stored to the currently active profile.
Have a look at this posting.
