• 12.11.2026, 12:19
nebj00la
Temperature Based Fan Control
Wednesday, November 12th 2014, 2:35am
I'm having trouble finding out how to make the following work:
26°C - Set fan channel 1 to 1000RPM, 50% power, etc
36°C - Set fan channel 1 and 2 2000RPM, 100% power, etc.
I've tried this with the controllers setting, however I can't have a given data source be in more than one controller. Using the example above, I'm only able to set the fan speeds when the temperature is 26°C. I want to be able to have various power/speed settings for various temperatures, for specific components.
Thoughts?
Thanks,
nebj00la
Wednesday, November 12th 2014, 7:24am
When you use a aquaero you can use a curve controller for every fan.
nebj00la
Thursday, November 13th 2014, 11:20pm
My problem is that I've got multiple data sources I want to trigger from. For example, if the CPU goes over 28c, push the fans to 70%. If the GPU goes over 28c, push the fans to 80%. I can't do both, as once I've configured my group of fans with the "CPU" curve controller, I can't use the same group of fans in the "GPU" curve controller. Making it worse, you can only have one data source per curve controller.
The two groups of fans:
360 Rad. - 3x 120mm Fans
240 Rad - 2x 120mm Fans
There's got to be a way around this, right?
nebj00la
This post has been edited 1 times, last edit by "nebj00la" (Nov 13th 2014, 11:34pm)
wa3pnt
Friday, November 14th 2014, 2:57am
Take a look at the virtual temperature sensors. I do not believe you can set different percentages, but you can set multiple conditions that will trigger an increase.
RodeoGeorge
Friday, November 14th 2014, 11:13am
Do Not use CPU or GPU temp for fancontrole.
nebj00la
Friday, November 14th 2014, 4:23pm
What do you recommend?
Friday, November 14th 2014, 6:14pm
Watertemp. The CPU,GPU temps jumping all around the place according to the load. Approximately 15° in 2 second, idle to full and back.
Jakusonfire
Saturday, November 15th 2014, 2:37pm
+1 to this. You can use a virtual sensor to combine CPU and GPU temp into one and use the 'highest temp' function so that if either temp climbs it activates the fan curve but as has been said it just leads to fans ramping up and down for no purpose. Water temps change slowly and the fans being controlled cool the water, if the water is still cool the fans speed up for nothing.
To get an easy water temp you can stick a standard flat sensor to a radiator or water fitting.
Also, a data source can totally be used in more than one controller. I use a single data source (a virtual sensor detecting air / water delta) for 3 different controllers.
This post has been edited 2 times, last edit by "Jakusonfire" (Nov 15th 2014, 2:46pm)
wa3pnt
Saturday, November 15th 2014, 6:10pm
Another option, as I have done in my past three builds, is to place a temperature probe against the side of the CPU before installing the CPU Block.
The temperatures from this probe will be "ahead of the power curve" on increasing loop temperatures but the probe will lag any spontaneous increases.
RodeoGeorge
