• 17.11.2026, 19:07
Cenedd
Answered: Pressure relief membrane
Wednesday, December 10th 2014, 8:48pm
I've just started filling my loop to leak test. I'm worried that because the Aqualis reservoir is mounted below the radiators, that the water will flow back and the pressure relief membrane will let the water escape into the case. Can this happen or am I worrying about nothing?
Many thanks,
Gareth
This post has been edited 1 times, last edit by "Cenedd" (Dec 12th 2014, 5:19pm)
sverreb
Thursday, December 11th 2014, 12:50am
To flow back from your top mounted radiators the fluid would have to evacuate the radiator, unless atmospheric air can get there only vacuum can then remain. Vacuum excerts no pressure on the fluid, while atmospheric pressure works on the fluid in the reservoir. Atmospheric pressure is approximately equal to the pressure of a 10m water column, so unless your radiator is mounted more than 10m above your reservoir or atmospheric air can get into the radiator the water will be kept firmly in place and there will be no risk of overflowing the reservoir.
Cenedd
Thursday, December 11th 2014, 9:08pm
Thank you Sverreb. It's really helpful to get an answer with an explanation behind it to back it up. For what it's worth, you were absolutely right. Once I'd closed the loop at the top by the radiator - which I had open to assist in letting the air out - I no longer had a problem with coolant flowing back into the reservoir.
Many thanks,
Gareth
