• 19.11.2026, 07:24
Bytales
Connecting 6 PA to Aquaero 6 XT
Monday, January 12th 2015, 11:34pm
I somehow missed this bit of information..
How do i get to connect the whole 6 Poweradjusts to my Aquaero ?
I only got the possibility to connect the aquaero 6 XT directly to the motherboard header, and i need to somehow connect all 6 Poweradjusts directly to the Aquaaero.
pcRelic
Tuesday, January 13th 2015, 10:33am
No need for "aquabus Y adaptor 3 pins" as PAs have two aquabus connectors. Just connect the 6 PAs in serial to the Aquaero via aquabus with the cables included with the PAs.
[img]http://public.dm2301.livefilestore.com/y2pO9IXfBYykEYx5BdMjEvzvb0A-HBgJ7mxJdWXaXJsk1oflUoTkJlT9exj57sXRqmiCLfE3edJPwUGgkxe8lTmer_UZ8UWg_OMsEvvFirUDhc/IMG_1162.jpg?rdrts=95765551[/img]
This post has been edited 2 times, last edit by "pcRelic" (Jan 13th 2015, 10:35am)
Bytales
Tuesday, January 13th 2015, 10:02pm
So its basically a chain between all the products, using aquabus ports, and the aquaaero 6 with the usb ot the motherboard. Thanks for the photos and pdf, very helpfull.
Bytales
Wednesday, January 14th 2015, 1:22pm
These are basically normal 3 pin fan conectors, right ?
mandrix
Wednesday, January 14th 2015, 6:41pm
Yes they are identical to fan connectors.
Also don't forget to assign each PA a different bus address (50,51,52, etc).
avictord
Thursday, January 15th 2015, 5:15am
Further to mandrix point. I would connect each of the PA's to a USB header to set the unique address (50,51,52 ...) first up and upgrade any firmware.
If you have enough USB headers I would leave the PA's on the USB and also connect them via the Aquabus connection in series. It makes the PA's more manageable. Test it on Aquasuite and you will see why.
Bytales
Saturday, January 17th 2015, 11:30am
I also need to add the 2 ''round pumps" the ones that are on the radiator with pump from airplex radiator series, to the aquabus.
Is that manageble, i ask because they have only one aquabus port.
Perhaps i can add one the the last aquabus port left free on the last poweradjust, and the second pump ia the usb fan header that remains free after one gets occupied by the AquaAero 6 XT (thats how i will connect it to the Computer)
Basically one would need to have 9 USB port free inside computer to connect 1Aquaero, 6 PA and 2 Pumps.
Perhaps there can be only USB connection for the AquaAero 6XT, through motherboard header, and everything else via Aquabus ?
Bytales
Saturday, January 17th 2015, 11:38am
I dont have so many header, and even if i would, they would be on the motherboard, and it would be a cable mess.
Its going to be anyways a cable mess as it is, since my build is overkill (just placed an order worth 650euro on ModDiY with different cabling connector an stuff, it is going to take some time cabling and routing all the stuff), and i would want, if it would be possible, to connect everthing through USB header the Aquaaero gets connected to the motherboard.
Bytales
Saturday, January 17th 2015, 7:23pm
How do i set the USB unique adress ?
If you have lots of Stuff that need to go to the Aquabus, you can wire it all if you got enough Y connectors ?
Because it just hit me, i am going to also need to wire 2 flow sensors to the aquabus.
So basically, i am going to set it up like this, if it will work
Normal Y connector,
Chain 1: The 6 PA serial connectors
Chain 2 will be further split 4 way
Chain 2.1 Pump 1
Chain 2.2 Pump 2
Chain 2.3 Flow Sensor 1
Chains 2.4 Flow Sensor 2
Just lookin on the AquaAero Manual, and noticed the AquaAero also has a Flow Connector.
Is this where the Aquabus Connection from a Flow meter will go ?
If so, the following configuration could also be used, which will be easier to do.
4 Way Y Connector goes to the Aquabus port of AquaAero
Chain 2: Pump 1
Chain 3: Pump 2
Chain 4: Flow Sensor 1
Flow Sensor 2 goes to the Flow Connector of AquaAero.
Let me know what you think !
Bytales
Sunday, January 18th 2015, 12:47pm
Here is how i plan to wire everything up. I hope you can see it good since the resolution of the file is pretty big.
1)The question that is to be raised is the following.
I quote from AquaAero 6 Manual
Maximum current is 2.5 A per output independent of output voltage, resulting in a maximum power of 30 W at 12 V. Outputs will be switched of if amplifier temperatures reach a critical level and will automatically be reactivated when cooled down. If an output current of 3 A is exceeded, the out put will be permanently disabled.
My AquaAero has the red HeatSink, and also the watercooling block.
As you can see from my diagram i have some fans groups that are exceeding 2.5Amp together. I suppose they will work, since it is no more than 3 Amp and the AquaAero is properly cooled.
But the small 40mm Delta Fans have an initial Current Draw of more than 3 Amp, allthough they are sucking continuosly less then 2.5 Amps
Will it work or not ?
2)The other question is if the Aquabus wiring i showed in the picture will work with the devices i plan to wire this way, or should i strive to connect them somehow through USB ?
Only the AquaAero will connect to Motherboard USB.
Also i want to say that i am planning to do the splitting using Wago Connectors.
Here is the normal Y-Type Splitter
https://eshop.wago.com/JPBC/0_5StartPage…D=WAGO01&zone=7
And here is the 4-Way Y Splitter
Will also be using these for wiring od the fans. Each wire will require its own connector.
They are going to be sticked with double addesive tape inside the case.
This is the version that can be used to extend wires, like i am probably going to need to extend the power wires of the radiator pump, they are going to get connected this way directly to the power supply.
Bytales has attached the following image:
This post has been edited 1 times, last edit by "Bytales" (Jan 18th 2015, 12:57pm)
avictord
Monday, January 19th 2015, 1:26am
Hi Bytales,
The Delta fans selected are extreme end are they really necessary. Do you require the CFM? If you rationalize the fans and exchange these Deltas for a lower Amp fan you can reduce the number of PAs.
Bytales
Monday, January 19th 2015, 12:04pm
Yes, they are extreme, yes i could reduce them, and the PA, but i allready got six PAs mounted, and i gotta fille em up with something that can proper load them. Besides, i want to hold the GM Titans under load at 25 Degrees.
Thats why its called Project Fill it UP.
The question that remains is whether the 4 smal Delta 40mm fans will be ok on a single Aquaero chanell.
And if the displayed Aquabus Splitting will work as intended. Or should i try to connect them through a USb hub ?
Monday, January 19th 2015, 1:51pm
Aquabus is ok, you only need to connect the PA´s and MPS´s once on usb to set the Aquabusaddress and Update the firmware.
If the Delta 40mm to much you can combine two of the PWM and connect there Powersupply directly to the power-supply unit.
Bytales
Monday, January 19th 2015, 5:17pm
You can always connect fans to power Supply. But the whole point was to have it wired through AquaAero. Probably im going to have to look for some other fans, as the manual states that if the Amperage draw is more than 3 per Chanell it will shut off.
So the 2-Way Y and 4-Way Y Connection of the Aquabus as drawn will indeed work. Its good to know. Im still trying to figure out how i am going to wire 11 pieces of equipement on USB inside the case.
Monday, January 19th 2015, 6:08pm
No, i mine get the PWM Signal from the AquaAero and 12Volt and Mass from the power Supply, then the only limit is the PWM Signal strength.
Quoted
It is a parallelbus, you put all parallel and it is ok, the PA´s are a line but the parallel wire, too.
Bytales
Monday, January 19th 2015, 8:48pm
Quoted
Hmmm, i didnt thought of that !!!
Since the fan port on Aquaero 6 are all PWM, one could get away with connecting the power of the Fans to the PSU, and the PWM signal cable to the AquaAero, then it wouldnt draw power through the Fan Port of the AquaAero. Ahahahahaha, then you could connect higher power fans that exceed 3 Amp together directly to the PSU, and only the PWM signal cable to the AquaAero.
OMFG, why coulndt i have though of it in the first place. Now i can use the Delta Fans without a problem and for the last group all 3000 PWM fans, yupiii !
What came up new is that fact that i will be wanting to have all the stuff permanently connected through USB for configuration purposes, and i am now looking up into how i can make a cable with proper usb connector from the 5 port dupont usb pins all the stuff is equipped with. If not im going to be forced to use the NZXT internal USB hub. And in the end i might end up using it, i still need to create one such cable though as i am going to be forced to connect the aquaAero through a normal usb connector on the hub instead of from the header.
6 PA, 2 Flow Meters, 2 Pumps, will make for 5 double pin usb 2.0 headers.
Using 2 x NZXTs i will be getting exactly 5 pin groups free, since one will be used connecting the second hub to the first. Therefore the only way would be to connect the AquaAero to the normal USB connector on the hub.
Or create cables for each device, 11 in total and hook em up to a 12 port USB hub i must place inside.
Still thinking into what i should do.
I do believe using this cable,
http://www.moddiy.com/products/Shielded-…252d-Black.html
and this USB connector
http://www.moddiy.com/products/Gold-Plat…-Connector.html
and a 5 Pin Dupont Housing Connector one could create the required cables one would need to hook everything up to a HUB, would i be right ?
avictord
Tuesday, January 20th 2015, 10:05pm
Now I understand what your trying to achieve. I'll subscribe to your build. :thumbup:
Certainly concur with EnigmaG. You may consider a power hub for the Deltas. Although its the noise with the fans at high RPM, assuming they are high thirties in dBA, could be a factor.
Bytales
Wednesday, January 21st 2015, 9:44pm
What do you mean by Power Hub ? Which Deltas do you mean !
Regarding the USB Connection to the Computer i think i might have found the solution
Through this adapter:
http://www.bitfenix.com/global/en/produc…l-usb3-adapter/
im going to connect two of these:
http://www.hubgear.com/usbg-7u3ml.php
The Hubs will give me in total 14 USB slots, and since i will need 11, i will be left with 3 spare.
The hubs im going to stick with double Adhesive thape inside the case, their thickness is small enough to fit inthe back of the STH10 case.
And maybe i wont even need to power it, if im going to connect only the stuff from AquaComputer to them.
6 for PA, 2 for Pumps, 2 for Flowmeters, 1 for AquaAero.
1 for Bluetooth, 1 for Wireless Headset, and i still got one free just in case.
The only thing that remains is to make my own custom lenght USB cable with USB connector on one side and DUpont 5 pin connector on the other side.
Im ordering the required parts from ModDiY to be able to make my own custom lenght USB cable.
I could have used this one here for more USB slots,
http://www.hubgear.com/usb3-16u1.php
but it is beeing connected through only one USB cable, which means 16 ports thorugh a single usb cable. But i have 2, which means 7 port per cable instead of 16, it might even work without additional power.
Thursday, January 22nd 2015, 1:43pm
Are you sure that BitFenix adapter is useful in your application? It has 2 Female A type connectors for the output and the USBG-7U3ML USB Hub you specified uses a USB Male B type connector for the input.
Have you considered two NZXT IU01 for your USB Hub?
The IU01 supports USB 2.0, not 3.0, but I don't believe any of the items you listed take advantage of USB 3.0.
You would have a total of 16 ports, 12 with the more compact/clean internal 5 pin connectors (1 spare) and 4 of the external A type connectors for Bluetooth & Wireless Headset (2 spare).
The external power is a simple 4 pin Molex pass-through, which you can pick up anywhere in your case... no additional power supply.
The IU01 cost is 20% of the USBG-7U3ML.
