• 06.10.2026, 11:15
Wredny
Aquaero 5 LT - temperatures at low voltage
Wednesday, January 21st 2015, 9:11pm
Hiya all, i have small trouble... my Aquaero 5 LT hits 90+ C with 4xCorsair SP120 LED plugged in (in one 3pin port) on voltage 5-7V... at 12V temperatures are around 45. The funniest part is that on 4xCorsair SP120 nonLED plugged the same way, on every voltage (5,7,12V) temperatures are great...
nonLED fans have 0.09A (12V), LED have 0,26A at 12V. This mean i have to buy waterblock for it..?
This post has been edited 1 times, last edit by "Wredny" (Jan 21st 2015, 9:15pm)
pcRelic
Thursday, January 22nd 2015, 10:55am
Waterblock, or maybe this should be enough: Heat sink for aquaero 5
Jakusonfire
Friday, January 23rd 2015, 7:09am
The more power the fans that are connected use, the more power the aq5 has to get rid of at lower voltages. That creates more heat.
The heat sink should be enough to bring temps under control unless you plan to use many more of the led fans.
Similar threads
