• 12.11.2026, 23:27
Jsep87
Order inquiry...
Thursday, February 26th 2015, 2:05am
I placed my order on the 19th of February and my order still hasn't shipped or anything. it still just says, "processing order"... Is this normal? whats the deal?
Bytales
RE: Order inquiry...
Thursday, February 26th 2015, 9:53am
Welcome to the club, i ordered stuff in november 2014, and i still need to receive a double circuit radiator from that order, supposedly it should arrive this week, but still havent received anything yet.
Another order that i placed on 8th of february shipped, but the radiators from that order are going to come sometime in the first 2 weeks of april
So if you have radiators, i think we need to wait.
The best bet would have been to buy the radiators from a third party who has them in stock, but the 140.2 double circuit copper blades radiator, i believe no one has such an exotic radiator in stock, so i ha to order from them directly.
Still waiting ! :S and waiting ! ?( and waiting :thumbdown: and waiting X( and waiting :sleeping: :sleeping: :sleeping:
Jsep87
RE: RE: Order inquiry...
Thursday, February 26th 2015, 10:16am
Oh My Lord... I was under the impression that this stuff would be at my house in 2 weeks... 3 weeks Tops. Im pretty sure they have all of my items in stock... They were in stock at the time that i ordered them anyway... lol.
I ordered 2x LGA 775 cuplos XT Nickel CPU blocks (dual cpu motherboard *intel skulltrail*)3x kryographics gtx 680 nickel/glass, 1x 360mm XT radiator and 1x 240 XT radiator. 1x AE 6 XT, (with heatsink and waterblock) 1x Aquastream XT ultra 5l of glowmotion.... I wanted the faberwark, but I figured I should get the main components in first then fiddle with the smaller things.. Anything you think that I should add?: also ordered 2 G1/4 temps sensors and 1 Res temp sensor. and an ATX 24 pin Standby power thingy with the 3 contact relay (do I need that)_lol ?( .... ummmm and a few other odds and ends. I held off on the reservoir, tubing, and connectors... planning on going to 3rd party for those.
Thursday, February 26th 2015, 11:40am
For the best result as to the status of your order, use the contact information provided you in the farbwerk thread,
Jsep87
Thursday, February 26th 2015, 12:11pm
It was quite helpful my friend. Thank you for the replies. : )
Any advice on my order? This is what I've got so far. Lol and not sure how much more I can afford at this rate ! >8 )
Friday, February 27th 2015, 2:59pm
I am just finishing my first external radiator build, so I am not an expert on this subject,.. particularly regarding an EOL dual processor board.
I do see 3 things I will comment on:
1. item 10 (53093) - the water block is probably not needed due to the switching technology implemented with the aquaero 6 - the aquaero 5 used analog technology and generated great heat when modulating fans.
2. item 11 (53138) - the pressure equalization membrane is used on a reservoir when a pressure/level sensor return line (low) is not implemented. I see no pressure/level sensor in your list.
3. item 15 (34021) - you stated you were going 3rd party for reservoir, tubing & connectors, but the aquabox professional IS a reservoir.
Bytales
Friday, February 27th 2015, 7:24pm
switching technology, by that you mean pwm modulation ? Regardless, i have installed a waterblock on my aquaero 6 xt also.
Anyways, temps will be better.
Friday, February 27th 2015, 11:50pm
This: aquaero 6 introduction
Quoted
The new aquaero 6 is an improved version of the aquaero 5. Our main target was a dramatic increase of the available power on the outputs. Other than the aquaero 5 which works with an analog voltage control, this time we used very efficient switching controllers of the latest generation. The performance capability of the aquaero 5 is mainly limited by the temperature of the voltage regulators since they become pretty hot when you attach some stuff and use it with lower voltages. The aquaero 6 has no problems in this area and the maximum power is only limited by the current which means you can go to the limits without worrying about the temperatures.
Saturday, February 28th 2015, 11:22pm
Are you sure? The water loop will run hotter than the ambient air.
Bytales
Sunday, March 1st 2015, 10:59am
Yesterday i received a big Package from aquacomputer, so i had hoped the double circuit radiator would be inside. Unfortunately i "only" received the 140.3 pump radiator and the normal 140.3 radiator.
It seems the "legendary" double circuit radiator has a long crafting time. It would probably add a few good points to "Engineering Skill" once it is ready.
Bytales
Sunday, March 1st 2015, 11:02am
Well, if it really doesnt get heated at all, then it really makes no sense in watercooling it, doesnt it ? Since as you said the water will be hotter than the ambient air. I should conisder then taking it out of the loop.
SO it really makes no sense in watercooling Aquaero 6 XT, doesnt it ?
What does AquaComputer recommend ?
Sunday, March 1st 2015, 8:43pm
Quoted
Maybe it does. A little further in the post it says this:
Quoted
The maximum current per channel is 2,5A (30W at 12V) without any special cooling. The aquaero 6 does not even have a passive heatsink! Anyway, we will also offer a waterblock for the aquaero 6 since it will allow to go a bit further with a maximum of 3A (36W at 12V).
But I have not seen a water block for the aquaero 6... maybe it is still coming, but it has been almost 2 years since the 6 was introduced.
I do have some empirical data I can share.
I have a aquaduct 360 XT mark V currently connected to my system. The XT mark V indicates an aquaero 5 is incorporated and it drives three 120mm fans
And I am building a airplex GIGANT 1680 with aquaero 6 PRO driving two 180mm fans, which is in the commissioning mode.
The picture on the left shows the aquaero 5 fans set to 35%, and fan amplifier temperatures (1 to 3) on the right
The picture on the left shows the aquaero 6 fans set to 35%, and fan amplifier temperatures (1 & 2) on the right
The aquaero 6 fan amplifier temperatures run fairly cool, while the aquaero 5 fan amplifiers are HOT.
This post has been edited 1 times, last edit by "InfoSeeker" (Mar 1st 2015, 8:46pm)
Railgun
Monday, March 2nd 2015, 11:40am
IIRC, the same block is used as currently exists. The passive block for the 6 had provisions for the water block and has instructions on mounting.
