• 05.10.2026, 12:54
dhg66
Fan splitter and AQ6
Thursday, March 12th 2015, 4:21am
trying to control a bank of fans with the AQ6 running to a 8 way PWM fan splitter. The splitter gets power from a SATA power connection (only 2 wires are connected power and ground ) and the fan cable connector from the splitter that goes to the AQ6 only has the RPM wire and PWM signal wire connected. Will this splitter work or do all 4 wires need to connect from the AQ6 ie 12 V, ground, RPM and PWM..and power not come from the SATA power cable.
Would appreciate clarification before I get to wiring things up.
Thanks in advance
Jenko97
Thursday, March 12th 2015, 2:01pm
I think that if you set the fan channel to PWM mode, then only the rpm and pwm signals are sent meaning it should work. I control my pumps that way and they are powered independently from the aquaero by my power supply via molex.
Hope this helps. :)
dhg66
Thursday, March 12th 2015, 11:32pm
thank you, sounds like the same set up just molex vs sata power,
