• 06.10.2026, 05:35
jmonteiro
Aquaero controlling RED LED (not RGB)
Saturday, March 14th 2015, 5:13am
Can the aquaero control RED LED 5mm (not RGB, something like this) using the PWR 1/2 output ports?
If so, what is the connector I need to connect to the ports? Is it a normal 2 pin connector like the ones on the temperature sensors? Also, is there an adapter to convert from the 4-pin molex to the 2-pin I need to connect to the aquaero?
Sorry for the amount of questions :(
Thanks,
Jorge
Jenko97
Saturday, March 14th 2015, 12:07pm
Should work. I once temporarily did something similar with phobya LEDs which are pretty much the same thing.
I would use one of these: http://shop.aquacomputer.de/product_info…roducts_id=1629 to connect it to the pwm power and completely ditch the molex connector.
jmonteiro
Monday, March 16th 2015, 2:04am
Thank you.
bcikota
Monday, March 16th 2015, 2:40pm
Just to confirm you can, indeed, control LED's through the output ports.
I'm controlling a couple of these: http://www.bitfenix.com/global/en/produc…emy-led-strips/.
Brightness setting is a bit rough, but you can control it somewhat.
Kind regards,
Boris.
Jakusonfire
Tuesday, March 24th 2015, 4:17am
The 'Darkside' brand dimmable LED strips work very well with a good range of brightness on the Aquaero 2 pin PWM power ports
Similar threads
