• 02.10.2026, 12:25
Railgun
Aquasuite 2015-4
Monday, March 16th 2015, 7:13pm
I may be preempting this, can we get a fix/feature list for 2015-4?
Thanks.
bcikota
Monday, March 16th 2015, 8:17pm
Roughly translated from the German forums:
Changelog for aquasuite 2015-3 to 2015-4
Bugfix: when more than one device is connected not all software sensors transmit correctly
Bugfix: the service is no longer supported on Windows 10 or the .NET Framework 4.6
Bugfix: displaying instruments could generate a memory leak under certain conditions
Bugfix: fan speeds from AIDA64 are now read with the correct unit
Bugfix: corrected errors in the controller curve representation
Firmware 2002 Aquaero 5/6 and aquaduct 360/720
Bugfix: error in start-up behavior of the curve controller when the first point of the curve was set greater than 0%
Bugfix: changed the default values ​​for the alarm timeout; changed from 10 to 20 seconds (prevents false alarms at start-up)
Fix: time display in the 12h time format was incorrect at 00:00 clock
Bugfix: pump in the aquaduct can not be controlled by data source
Bugfix: fixed partially incorrect selection marker in the device menu
Fix: the pump speed was cut off on the display
Kind regards,
Boris.
