• 30.11.2026, 23:28
sircody01
Customized fill level control
Wednesday, March 18th 2015, 8:30pm
I decided I wanted to create a fill level control that would display 10 different levels instead of just the 3 that come with the factory install. I am releasing it into the public domain. Attached are all the files you need to make this work on your system.
1) Extract the images out of the .zip file and place them into your C:\Program Files\aquasuite\Content\images folder.
2) Create a new Custom Control on your Overview Page
3) Select your fill level sensor as your data source
4) On the Display tab, copy the contents of the attached "Custom Fill Level Control1.xaml.txt" file into the content pane.
5) Click OK
6) Size and position it to your liking
You now have a 10 level display of your fill level sensor.
DISCLAIMER: This code comes with no warranty or guaranty of serviceability of any kind. I will not be held responsible for anything that happens to you or your computer as a result of using this custom control.
sircody01 has attached the following files:
Wednesday, March 18th 2015, 9:27pm
Very nice, thank you. :)
bcikota
Wednesday, March 18th 2015, 9:32pm
Thank you for sharing!
Kind regards,
Boris.
Railgun
Monday, March 30th 2015, 9:42pm
Thanks as well. Using it with no issues and was very straight forward.
sircody01
Tuesday, March 31st 2015, 1:24am
You're welcome! It's nice to know the instructions were straightforward and easy to follow. :)
