• 29.11.2026, 11:36
Blade Runner
Aquabus Conections
Tuesday, March 31st 2015, 9:14am
I know that you can connect lots of Aquabus devices with Y splitter cables but I would like to know if it can be done this way too.
In one half of my loop I have a 6 XT with a real time clock attached (RT Clock has 2 aquabus terminals), a Farbwerk (2 aquabus terminals), an Aquastream pump and a AQ High flow sensor;
Can I connect one of the Aquabus connectors from the real time clock to the Farbwerk, the other real time clock Aquabus terminal to the pump and the second Farbwerk Aquabus terminal to the flow sensor?
Tuesday, March 31st 2015, 10:22am
this is possible. The RTC is the same like a y splitter cable.
Tuesday, March 31st 2015, 10:28am
Sebastian,
Is the specified "High flow sensor" an aquabus device? I thought it needed to be connected to the "Flow" port on the aquaero 6?
This post has been edited 1 times, last edit by "InfoSeeker" (Mar 31st 2015, 6:49pm)
Tuesday, March 31st 2015, 10:33am
High flow sensor
The normal high flow sensor is NO aquabus device, the Highflow USB (MPS based) is a aquabus device.
Blade Runner
Tuesday, March 31st 2015, 11:14am
Thanks to both of you.
Does the high flow sensor connected directly to the flow connector on the Aquero still show up in the Aquasuite?
I have not bought the 2 flow sensors yet, would I be better with the expensive :-) one with USB etc?
This post has been edited 1 times, last edit by "Blade Runner" (Mar 31st 2015, 11:22am)
Tuesday, March 31st 2015, 12:22pm
Quoted
Yes, I believe it does.
Quoted
You say you have 2 loops... does each loop have an aquaero 6 XT?
Blade Runner
Tuesday, March 31st 2015, 5:41pm
Yes I have 2 Aqueros
Tuesday, March 31st 2015, 6:49pm
Each aquaero has a Flow port, so you can use one Flow sensor "high flow" on each aquaero.
The following text is a Google translation from the manual
Quoted
Adjustment of the calibration:
● When using a Aquaero with LCD display, the
Calibration can be adjusted directly on the device. The exact
Procedures, refer to the instruction manual of the
aquaero.
● For all other devices is a USB connection to PC
is required. The setting of the calibration must be unique across
the software aquasuite be made. The software
you can free www.aqua-computer.de from the site in
"Support" - "Download" to download. After
Input of the calibration you should use the settings permanently
within the device, aquasuite the software can then
be terminated.
● The calibration of the flow sensor "high flow" is 169
Pulses / liter. A precise measurement is from a flow of
80 l / h, where, in the range of 40-80 l / h, the output
Signal is not completely linear with flow rate. Can if required
The calibration value in this field by measuring itself
and enter it on the device.
If you go with the Flow sensor "high flow USB", then as Sebastian said, your original configuration will work.
