• 11.10.2026, 00:23
Bytales
Troubleshooting the Whole Lot of Aquacomputer Parts
Monday, April 20th 2015, 1:18pm
So the aquaero 6 xt usb connection doesnt work anymore.
Originally the cable i made myself didnt work at all so i took its original cable and connected it to the nzxt hub and it worked.
I so managed to set the fans to more ear friendly levels. Later on after i used the cable to connect my flow meter, after reconnecting the aquaero again it isnt working anymore.
In aquasuite the aquaero is being displayed with usb cutoof. When i plug the cable in usb i can hear the usb sound in windows, but it is not being recognized.
I have ordered a new set of usb cables. Decided to throw away the cables i made and use something else....
Any ideea of how i can make thiss fix?
Is there a posibility that the connection is broken due to a bad cable pin out?
Ill see what can i do once the cables arrive.
If the usb connection is dead, can i change fan speeds from within the aquaero itself? Or are they stuck as they are?
This post has been edited 1 times, last edit by "Bytales" (Apr 21st 2015, 11:45am)
InfoSeekerX
Monday, April 20th 2015, 2:55pm
You may try deleting the aquaero tab in aquasuite, and then restarting the system & aquasuite with the USB connected.
Bytales
Monday, April 20th 2015, 4:07pm
Will try to see what it gets me. Tommorow i should be having the other cables.
What about the fan settings ? If the USB connection is not available any more, can these be changed, or are they stuck as they are now ?
Bytales
Monday, April 20th 2015, 6:21pm
Nope, doesnt work !
InfoSeekerX
Monday, April 20th 2015, 8:40pm
OK, I think we had different issues then... unfortunately that is all I have, you may want to contact support.
As to the fans, I believe they are controlled by the aquaero, and if you can't access it you may not have control from aquasuite.
Do you have the infrared controller?
Bytales
Monday, April 20th 2015, 10:40pm
I do, and i need new batteries, and see what i can get out of it.
It should function independently of wheter the aquaero is connected through USB or not.
Bytales
Tuesday, April 21st 2015, 11:45am
It seems to be working now, i had some poweradjust on the same aquabuss adress, perhaps that was the culprit, i dont know !
Similar threads
