• 14.10.2026, 19:48
Piospi
D5 with PWM for my Aquaero 6
Tuesday, June 9th 2015, 10:30pm
Hello everyone.
I've heard that the D5 PWM pumps have a problem with aquaero 6. I'd like to just make sure that this pump will work well with aquaero 6: http://shop.aquacomputer.de/product_info…roducts_id=3255
It will be good?
I would take the USB version, but I can't - I want mod kit from Bitspower.
Sorry for the noob question :rolleyes:
bcikota
Tuesday, June 9th 2015, 11:16pm
Hi Piospi,
The pump will work with your aquaero without problems.
It is even mentioned in the item description in the shop:
Important: The Aqua Computer D5 pump has an optimized
PWM input and can be used with any Intel PWM standard compatible fan
controller. This pump can be used with aquaero 5/6 PWM fan outputs
without any heat dissipiation at the aquaero. All other currently
available (as of January 2015) D5 pumps with PWM input use different
hardware that will not work correctly with the PWM outputs of aquaero
5/6 devices. This pump is compatible with nearly any PWM fan controller
on the market.
Kind regards,
Boris.
Piospi
Monday, June 15th 2015, 10:36am
Hi Boris,
PWM input......
Arghh, I didn't notice this :huh:
Thank you for the answer :)
Jakusonfire
Tuesday, June 16th 2015, 4:08pm
The bitspower pump cover kits do work with the USB version D5's beause the rear section of the cover is a separate piece that does not need to be used or you can cut slots for the connectors.
The rel tricky ones are the EK version because they are one piece but I just cut slots in the back and it works great.
Similar threads
