• 08.10.2026, 19:48
Lupus
Aquaduct 720: can I put it sidewise (horizontaly)?
Tuesday, June 16th 2015, 6:07pm
Hello!
Need some advice. What do you think, can I put my Aquaduct 720 to the side (horizontaly, not verticaly)? Or is it forbbiden and it might break? ;(
Thank you :)
Wednesday, June 17th 2015, 6:10am
I don't think it wise.
I believe the flow goes from bottom to top on the left side (facing the front), spills over to the right side at the top, and then feeds into the pump at the bottom.
If you were to lay it on the side, be sure to have the right side down so as to keep the chamber feeding the pump full. But I certainly would not do it.
Reveal
RE: Aquaduct 720: can I put it sidewise (horizontaly)?
Wednesday, June 17th 2015, 7:54am
No...
Hello!
Thank you:)
Lupus
Wednesday, June 17th 2015, 9:30am
Thank you!)
Lupus
RE: RE: Aquaduct 720: can I put it sidewise (horizontaly)?
Wednesday, June 17th 2015, 9:31am
No...
Hello!
Thank you:)
Thanks!)))
Similar threads
