• 02.10.2026, 17:24
garyd52
fan speeds by controller
Wednesday, July 22nd 2015, 6:20pm
Hi , I have an Aquaero 6 which I use to control 2 laing ddc's and an aquastream ultra I have 2 rads with 4 fans each in push pull and 4 temp sensors plus the one built into the aquastream the fans use a Y splitter I have tried to set up a fan curve to ramp up fan speeds with temperature and have tried using all the temp sensors plus the aquastream one as the data source, I want the fans to run at maximum speed once 40 degrees is reached and have used the auto setup to set the fan curve but it does'nt work I use occt to stress the system and bring the temps up but the fans do not respond at all, the fans are non pwm fans btw .
Wednesday, July 22nd 2015, 9:41pm
Could you post a screenshot of your controller setup?
garyd52
Wednesday, July 22nd 2015, 10:22pm
Hi yes i'm not that savvy with screenshots but hopefully this will work.
Wednesday, July 22nd 2015, 11:55pm
Nice screenshot, except you excluded a point of interest, the"Source" to the left of the curve. :)
EDIT: a screenshot of the aquaero>fans tab would be useful also. (sample below)
This post has been edited 1 times, last edit by "InfoSeeker" (Jul 23rd 2015, 4:27am)
garyd52
Friday, July 24th 2015, 12:30pm
Hi , the data source is an AC temp sensor located on the front rad and here is the fans tab
garyd52 has attached the following image:
garyd52
Friday, July 24th 2015, 12:34pm
i've done it again as I did'nt open the advanced settings in the first one
Friday, July 24th 2015, 4:20pm
I do´t see the Problem. By "Rear Rad outer" the spectrum is 46-89% Delta 43%
1% at the curve make 46+0,43%=46,43% at the fan
at start off your curve approximately 43% should it be 46+0,43*43=64,49% at the fan
At 95% 46+0,43*95=86,85% as it is in the first picture
This post has been edited 3 times, last edit by "EnigmaG" (Jul 25th 2015, 9:27am)
Friday, July 24th 2015, 7:39pm
What was the temperature reading of the sensor you use for the fan controller?
I see you have the "rear rad outer" fan set to go no slower than 46% and no faster than 89% of the power range.
The fan is running at 86%, so you are basically running the max as you have it set in the fan setup.
If you specify 46% min and 89% max in the fan setup, the fan controller can only work within that range.
garyd52
Saturday, July 25th 2015, 3:13pm
Hi , you've solved it for me , I stuipidly ignored the fact that the fans are controlled by the controller lol, I had them turned down to minimise noise but have now set them except the hideously loud zalman reds to 100% and my curve is doing the rest , I sometimes cannot see the wood for the Trees and thank you both for your help.
Similar threads
