• 29.11.2026, 07:52
[RESOLVED] HWiNFO fail
Saturday, August 22nd 2015, 11:58am
Couple weeks ago I decided to move from AIDA64 to HWiNFO64.
I was running win8.1/64 & aquasuite 2015-6.
Unfortunately, HWiNFO64 did not show up under the System heading in input select, and the shared memory function was checked in HWiNFO64.
Knowing I was about to move to Windows 10, and hoping the issue would go away, I ignored the problem until I updated.
I have now updated to Win10/64 (not clean install), and aquasuite works fine, but the same issue remains with HWiNFO64.
I have latest HWiNFO64 beta installed:
and Shared Memory Support checked:
yet HWiNFO64 does not list under the System heading when choosing input select:
Any suggestions?
This post has been edited 2 times, last edit by "InfoSeeker" (Aug 25th 2015, 5:49pm)
Monday, August 24th 2015, 3:35pm
Open the sensor panel, when this windows is not open hwinfo export no data.
Tuesday, August 25th 2015, 3:41am
Thank you for comment.
I made sure hwinfo was not only running, but that the main window was also open... unfortunately that did not seem to correct the issue.
Tuesday, August 25th 2015, 6:50am
NOT the Main Window, Click to Sensors! Only in this case sensor data exported.
Tuesday, August 25th 2015, 11:48am
:D
Tuesday, August 25th 2015, 1:58pm
Oooh, nice, that works :)
Thank you.
I will send Martin a suggestion to add to the mouse-over help balloon for the Sensor Window Open at start-up preference, that it that it "must be active to use the export function".
And a comment to correct the spelling ;)
Similar threads
