• 12.11.2026, 06:09
Housec84
Pathetic flow - aqua computer d5 - help!
Tuesday, September 8th 2015, 10:34pm
So no idea what is wrong - I fear the d5 is simply not powerful enough for my loop...
See video here of the very poor flow: http://youtu.be/J7g7t9eSaDM
Loop order is:
Pump - rad 240 - rad 480 - cpu - mosfet - rad 480 - dual gpu blocks - chipset - res
Also changing the pump from 100% to 1% (via aquaero) has absolutely no effect (percentage as given in top right corner on aquaero) - is my pump defective??
Hoping someone can please help!
-C
Housec84
Tuesday, September 8th 2015, 11:31pm
Additionally - flow rate is even worse when the aquaero isn't powered - literally just a drip into the reservoir... :(
Wednesday, September 9th 2015, 7:31am
You must setup the pump via USB. When the pump is running at full speed you have ~4800 rpm pump speed.
Housec84
Wednesday, September 9th 2015, 9:11am
So right now the pump is not running at 100% ??
The pump is the only thing plugged into th aquaero at the moment, so no issues with aquabus id's I hope. (It's detected,, just doesn't do anything)
Jakusonfire
Wednesday, September 9th 2015, 1:42pm
In the video it looks like the pump is not connected via Aquabus cable so the Aquaero can't control its speed.
It is connected via USB so you should be able to go to its MPS tab and manually adjust the speed. They normally come from the factory set at 100% though.
Edit: Never mind, I might have mistaken glare for an empty white Aquabus socket. I assume the Aquabus cable is under the USB cable in the video. If so, the pump must be set to Aquabus priority for the Aquaero to adjust its speed.
If you have that all set right then another alternative is the res. If that is one of the waterfall effect res then sometimes the centre tube is too long so the port plug at the top restricts flow i believe.
This post has been edited 2 times, last edit by "Jakusonfire" (Sep 9th 2015, 1:52pm)
