• 03.10.2026, 14:05
kdurning
pump question
Friday, September 11th 2015, 1:05am
I have an Aquaero 6xt, 2 poweradjust 3, and 2 Aquacomputer D5 Pump Motor with PWM Input. I am using all the 4 pin fan connections on the Aquero, the poweradjusts were bought to control the pumps. The fan connections on the poweradjusts are 3 pin, can i just change the connector and run the pwm off the 3 pin fan connector of the poweradjusts? If not can I utilize the 2 pin connector on the Aquaero?
edit: part number on the pumps are 41105
This post has been edited 1 times, last edit by "kdurning" (Sep 11th 2015, 3:23am)
Friday, September 11th 2015, 6:57am
No, the outputs ar voltage controlled not PWM.
No, the connector has a dirrerent signal - you can control with this connector LEDs (12V) directly, but no PWM Fan/Pumps.
Similar threads
