• 11.10.2026, 00:26
karoloydi
Is it possible to set farbwerk usb lights to turn off when watching movie?
Saturday, September 19th 2015, 9:49pm
I have the farbwerk usb LED controller. Can I set it so that when I launch Media Player Classic all the LED lights in my case will turn off?
Cause it is quite distracting to have bright light from the case when watching movies.
Saturday, September 19th 2015, 11:24pm
You can only turn it off manually. There is no way to do that in an automatic "if ... then ..." way.
karoloydi
Sunday, September 20th 2015, 1:53am
Ok. Thanks. Maybe it can be implemented in the future if it not too hard to do. I am sure a lot of people will find it useful
tomtalk24
Wednesday, October 14th 2015, 6:59pm
Might be a nice project for you, but you could write something that HWiNFO can read, may need to do some homework. So normal operation is "On/100", then when you load a media player your code sets this to "Off/50/0". Have a controller setup in Aquasuite with a software sensor pointing at your fake HWiNFO sensor. Job done.
Shouldn't be too tricky. I will be looking into manipulation some HWiNFO sensor some how in the future for a unrelated project, so if I learn anything will post here. Good luck.
