• 19.11.2026, 07:19
yvelt
ATI R9 290x Connection terminal for SLI/CROSSFIRE using Backplates with Active XCS
Wednesday, October 7th 2015, 8:00pm
Hi there
i'm new to the forum and to AquaComputer... i could not find a help line in English on the site hence i'm in this forum...
Could anyone tell me if there's a Connection Terminal Block for multiple cards (4 (23551) or 5 (23552) slots) with the additional slot for the Backplate with Active XCS (23587) cooling heatpiep to go into the water channels?
Is it possible to order a multiple card Connection Terminal that can work with 2 Backplate with Active XCS for my double ATI R9 290X cards?
Thanks
Thursday, October 8th 2015, 1:20am
These two Kryoconnect Kits are active back plate compatible for either 3 or 4 slot separation.
yvelt
Thursday, October 8th 2015, 1:58pm
oh cool thanks for the link :)
oh man issue is most of the 16x dual mother boards are 5 slots apart... older ones are 4 slots...
any chance they make a 5 slot connection block that works with ;) Active cooling back plate
Thursday, October 8th 2015, 3:53pm
Those two were all I saw in their shop.
Shoot an email to customer service at support@aqua-computer.de to see what their plans are.
Thursday, October 8th 2015, 3:58pm
We have no other adapters nor will we produce one.
yvelt
Friday, October 9th 2015, 2:58pm
oh darn, so for the 5 slots apart configuration with active cooling backplates, i will have to have a physical tube connecting both terminals? or run them individually to 2 separate radiators?
Friday, October 9th 2015, 3:57pm
If neither of those 2 bridges fit, then yes, you will have to manually connect them.
Which motherboard are you using?
yvelt
Monday, October 12th 2015, 10:05am
I have Asrock z77 Extreme 9 for a small upgrade to 3.0 with dual 16x rails (this is a 5 rails apart between both cards same as for the Asus P8Z77-V_Premium)
my older Asrock Z68 extreme 7 gen 3 only has 2.0 dual 16x rails *ivy 3770K just makes one rail 3.0. however this is a 4 rails apart between both cards.
Monday, October 12th 2015, 11:07am
Best I can tell looking at the manual, for 2 card SLI, this mobo says use slots 1 & 5, which has 3 unused slots between, and the longest kryoconnect kit has 2 unused slots between.
So, yes, you will need to interconnect the two GPU cards manually, which is not hard to do, and the look can be made to match the rest of your loop.
yvelt
Monday, October 12th 2015, 12:36pm
is there any Aquacomputer dealer in Singapore?
Tuesday, October 13th 2015, 5:05am
Not sure if you are looking for a brick & mortar store or if online will do, but Performanse-PCs has Singapore in their country list for shipping, so they may be an option.
Tuesday, October 13th 2015, 9:16am
We also ship to Singapore ;)
yvelt
Wednesday, October 14th 2015, 2:04am
just noticed a big price increase/revision on the website? now it's cheaper to get from the US sites instead
Wednesday, October 14th 2015, 2:14pm
Prices have not changed at all since a very long time.
yvelt
Fitting clearance on the Cupliex Kryos HF for socket 1155/1151 ... can it take 19/13 fittings and tubes?
Thursday, October 15th 2015, 8:20am
quick question about the CPU cooler
cuplex kryos HF for Socket 1366/1156/1155/1151/1150/775, G1/4
79,90 EUR
Can it take 19/13mm tubing fittings? or are the exit ports too near each other?
yvelt
Thursday, October 15th 2015, 8:23am
oh by i was checking out prices just last weekend and it all seemed to have jumped by15-20% in EUR? example the backpack was around 33.60 when i copied onto my list and later now it's 39.90
yvelt
Does a Radical 2/280 radiator with copper fin exist?
Sunday, October 18th 2015, 2:48pm
does aquacomputer make a Radical 2/280 radiator with copper fin? can't seem to find it
Tuesday, October 20th 2015, 12:12pm
The threads of the cupley kryos have a center to center distance of 23.75mm. Unlikely that this will work with fittings for 19mm tubes because I assume the fittings will be even larger than the tubing itself.
I assume the first time you were logged in with your correct address details so the VAT (19%) has been already removed. As said, we have not changed any prices lately.
The airplex radical 2/280 is not availavle with copper fins.
yvelt
Wednesday, November 4th 2015, 2:16pm
any one know where to get Ramplex instructions in English? the 2 sets i ordered came with instructions in German only...
Wednesday, November 4th 2015, 2:59pm
There is no English manual available for it. You can copy/paste the text from German PDF to translate it with Google for example.
