• 09.10.2026, 07:56
ZGIERA
How to connect 2 water pumps
Saturday, October 10th 2015, 8:57am
Hi there, I have a question which is
I have AQUAERO 6XT fan controller and 2 POWERADJUSTMENTS 3 ULTRA
Poweradjustment no.2 is connected to Poweradjustment no.1 and PA no.1 is connected to high speed port on AQUAERO 6XT
all fan connectors are busy on Aquaero and poweradjustments as well
so I'm wonder myself how to connect x2 AQUA COMPUTER D5 Pump Modules with RPM Signal in the best way
as far as I know I can connect 1 water pump to hihg speed port on AQUAERO 6XT via Y cable connector which I did but water pump won't work
and is any chance to control RPM of this water pump with Aquaero 6xt?
Many thanks at advance for any help
This post has been edited 3 times, last edit by "ZGIERA" (Oct 10th 2015, 3:09pm)
Monday, October 12th 2015, 8:52am
Are we talking about the regular D5 pump or the USB variant with aquabus interface?
If it is the normal pump you can only connect it to the fan ports using this adapter for example. Only one pump per channel!
If it is the USB variant you can use an aquabus y-cable to connect both to the aquabus highspeed port of the aquaero. Before you do this you have to change the aquabus ID numbers via USB in the system tab of the pumps.
ZGIERA
Monday, October 12th 2015, 11:00am
we talking about regular D5 pump which is (weblink to this product is below)
http://shop.aquacomputer.de/product_info…roducts_id=2750
I didn't buy USB vesion becuse it doesn't fit to BITSPOWER D5 Mod Kit (BP-D5MA-MBK)
I presume I can have control over the pump when I set up red dot in back at 5 speed level and then set up rpm on Aquaero 6xt, isn't?
mandrix
Monday, October 12th 2015, 12:45pm
It's been my experience that the vario version of the D5 pump like you linked don't control very well with Power Adjust or even a fan controller. I mean it's possible, and I've done this, but it's not for a very wide range of speed from lowest to highest.
I prefer the Aquacomputer pwm D5 and control with Aquaero...it's compatible with Bitspower dress kits as well.
ZGIERA
Monday, October 12th 2015, 2:42pm
I have already bought Aqua Computer D5 2 water pumps and need to find to out how to connect this in best way.
I have another two poweradjustments 3 ultra which one of these has 1 free fan port so if I will get another one so I will be able to connect these pumps to poweradjustments.
I have no clue how it will work? but I can't see any other way at the moment.
Regards
This post has been edited 1 times, last edit by "ZGIERA" (Oct 12th 2015, 2:43pm)
mandrix
Monday, October 12th 2015, 2:49pm
OK. :thumbup:
