• 13.11.2026, 00:47
siltsunrise
Manual? Tutorial? WTF?
Sunday, October 11th 2015, 10:30am
Aquacomputer people, if you are listening... why in God's name don't you offer some kind of manual or tutorial or help with setting up and using your software and hardware. This is completely idiotic! The device and software are pretty complicated and I have no resource to help figure it out. You don't even mention anywhere in your pathetic manual how to use other software to feed temp information to your own software, for starters. Had to try to figure that out from the internet. And still, I cannot get the damned stuff to work.
HOW ABOUT SOME FUCKING INSTRUCTIONS?!!!
My God, are you completely stupid? This is an expensive product and you make it impossible to use!
This post has been edited 2 times, last edit by "siltsunrise" (Oct 11th 2015, 10:35am)
Sunday, October 11th 2015, 11:44am
http://aquacomputer.de/handbuecher.html
When you have read the manuals the most of the device functions are clear.
RE: Manual? Tutorial? WTF?
Sunday, October 11th 2015, 4:19pm
I believe I answered your question about using HWiNFO sensor data in the aquaero in the OCN aquaero owners club, though your question appears to have been changed.
It takes time and effort for people to answer your questions, and I must say, you will see a much better result if you don't rage - it's a bit put-offish.
Namron
Sunday, October 11th 2015, 7:38pm
There are also guides out there if you google it...... My own guides even showed up HERE My guides are mostly for the AQ 5 But much of the actual setting up of the Aquaero are the same pretty much... The guides have pictures explaining how to set up basic control curves e.t.c.....
So... Calm down..... Take a Chill Pill & prepare yourself for a fairly steep learning curve & one that is going to require a certain amount of patience also....... Once you get your head around it you'll soon get the hang of it I'm sure :thumbsup: .....
tomtalk24
Wednesday, October 14th 2015, 7:12pm
I found it fairly easy to sort out. Just takes a little bit of homework, a few videos and some reading.
Quite a strong, very negative way of asking for help if you ask me. Might be your first problem.
Similar threads
